Hello Guest it is October 20, 2026, 08:50:09 PM
Author Topic: Reset Button problem.  (Read 14130 times)
  •  9,374 9,374
« on: October 26, 2009, 08:24:07 AM »
Up to now, I have always been able to operate the screen Reset Button from my keyboard using the @' key but recently this has stopped happening. I have obviously altered a setting somewhere but cannot find the cure.
Has anyone else had this problem and found the answer ?.
Re: Reset Button problem.
« Reply #1 on: October 26, 2009, 09:04:44 AM »
Check the screenset you are using has the @ as a HotKey.
  •  9,374 9,374
« Reply #2 on: October 26, 2009, 12:41:20 PM »
Hi Hood,
Thanks for the reply, it is very much appreciated.
I have checked the screenset, as suggested, and can confirm that the hotkey is enabled for the reset button.
I have concluded that it may not be a screenset related problem as I have two computers running Mach, my internet computer (the one I am using here) and my workshop computer. The same screenset works as expected on this computer but no longer responds to the @ key on my workshop one. I have also checked for different ascii values for the @ key on the different keyboards but the mystery of why it used to work but doesn't any longer still defeats me.
Any further suggestions would be well received.
« Reply #3 on: October 26, 2009, 01:14:17 PM »
Check that both machines are using the same Regional and Language settings.
Phil
  •  9,374 9,374
« Reply #4 on: October 27, 2009, 05:33:40 AM »
Thanks Phil, you got it in one.
Now both computers have the same regional and keyboard settings it is working as it should.
Thanks again.
« Reply #5 on: October 27, 2009, 08:25:50 AM »
OMG. I finally got something right for a change.
Phil
