Hello Guest it is November 01, 2026, 11:52:06 AM
Author Topic: problem with lazycam  (Read 33889 times)
« on: October 21, 2009, 11:03:16 PM »
sending a drawing in dxf autocad 2000
« Last Edit: October 21, 2009, 11:08:23 PM by Edmund »
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: problem with lazycam
« Reply #1 on: October 21, 2009, 11:37:51 PM »
Hi, Edmund
Hears a cleaned up file.
Chip
« Reply #2 on: October 22, 2009, 06:16:06 AM »
Edmund,
Have look at the LazyTurn Manual - Appendix "B" located in Members Docs. I t talks about common mistakes made in CAD.  The errors are generic.
Offline Chip
  •  2,055 2,055
« Reply #3 on: October 22, 2009, 08:47:54 PM »
Hi, Edmund
Give this a try.
Chip
« Reply #4 on: October 22, 2009, 09:28:22 PM »
this is the rocker
Hi, Edmund
Try this one also.
Chip
« Last Edit: October 22, 2009, 09:39:24 PM by Chip »
« Reply #5 on: October 23, 2009, 09:24:40 PM »
Hello Chip,
      tried out the gcode for the distributor rocker, matl used as a test was Delrin, the finished sizes were spot on, I will probably make the real part from Bakerlite or Tufnol, I would like to thank you for getting me going, and at the same time I have picked up a few learning curves for myself,
When I get the parts finished and assembled I will attach a photo, in the mean time here are a couple of photos attached to give you some idea,
Again thank you,.........Edmund.........
« Reply #6 on: October 23, 2009, 09:41:46 PM »
Edmund,
Hello Rich,
       my apologies for not getting back to you sooner, I've had a few busy days here, right now I am going to take your advise and check out the lazycam manual,
Thank you for your response to my predicament.............Edmund.........
Offline Chip
  •  2,055 2,055
« Reply #7 on: October 23, 2009, 10:19:16 PM »
Hi, Edmund
Glad to have helped get you back on track.
Anytime, Chip
« Reply #8 on: October 23, 2009, 10:24:54 PM »
Just post a picture of the motor when your done. Looks good so far.
Any problems with LazyCam just ask.
BTW, Thanks guys for taking care of the LC stuff, since as you know, i have been turning circles lately!  ;)
« Reply #9 on: November 02, 2009, 03:57:25 PM »
Hello Chip,
     I am having a little problem with transferring from LazyCam into Mach3, have success with the dxf in lazycam but after loading into mach no code, the lazycam project column informs that posting file, attaching to mach3, no mach3 found running, posting file complete, but no picture or gcode in Mach3,
any ideas what is wrong?, can I contact you by phone tonight after 9 pm your time?,
..............Edmund..............
