Hello Guest it is November 23, 2026, 02:22:28 PM
Author Topic: Feedrate really slow when running a line with G43  (Read 23616 times)
Offline mhdale
  •  130 130
  • Knowledge is the Treasure.
    • Black Dragon Technologies
« on: September 05, 2006, 05:51:52 PM »
What feed does the system use for a G43 Operation? When its performing this move its super slow and changing the feedrate on the screen does not affect it...
Mike
Re: Feedrate really slow when running a line with G43
« Reply #1 on: September 05, 2006, 07:12:16 PM »
There should not be a move when you do a G43... G43 is a tool length offset...
www.newfangledsolutions.com
www.machsupport.com
Offline mhdale
  •  130 130
« Reply #2 on: September 05, 2006, 07:27:58 PM »
Brian, Here is the Code in my file right after the tool change.
T1 M06
G20
S10000 M03
G53G0 Z0
G00 G90 X1.0914 Y1.4791
G43 H1 Z2.
The last line is the line it is on when its moving down to the starting position for the job.
I tried using the feedrate thing we discussed on the phone, but the feedrate showing on the DRO is 60 but it is only moving as fast as the speed I used for the last Tool Hieght probe move.... Any Suggestions?
M
« Reply #3 on: September 05, 2006, 07:43:21 PM »
Try putting a G00 on the same line as the G43. It should be going at G00.. that is odd
www.machsupport.com
Offline mhdale
  •  130 130
« Reply #4 on: September 05, 2006, 07:48:13 PM »
Thanks I'll give it a try.... I think ODD should have been my middle name ;)
Offline mhdale
  •  130 130
« Reply #5 on: September 05, 2006, 07:53:51 PM »
Brian, Tried a G00 on that Line.. No help there....
Mike
« Reply #6 on: September 05, 2006, 08:49:10 PM »
I just tested it here and it is moving at rapid speed... what version are you running?
www.machsupport.com
Offline mhdale
  •  130 130
« Reply #7 on: September 05, 2006, 09:00:43 PM »
R 1.84
Offline mhdale
  •  130 130
« Reply #8 on: September 05, 2006, 09:08:07 PM »
WHat does it mean when it says Cannot Find recovery Points solution too complex.... I get that when I first Start up.
« Reply #9 on: September 06, 2006, 06:39:09 AM »
That is a comp bug and has been fixed for the next release... when are gets the next release out I would like to have you update your copy as there are many bug fixes.
thanks
Brian
www.machsupport.com
