Hello Guest it is November 23, 2026, 03:56:57 AM
Author Topic: Problem in a curve drawings  (Read 10222 times)
« on: October 20, 2009, 05:13:41 AM »
Dear all,
I have a CNC machine with two Siemens Stepper Motors connected by two STEPDRIVE to the parallel port of a PC..
I am using Mach3, and Sheetcam (for converting from Autocad to G-code)..
When i have a straight lines drawing with any orientation, the motors go perfectly, even when increases the feed rate (Frequency of pulses)..
But when a curve or a circle is wanted to be drawn, the motors get stuck if i increases the feed rate little more !!!
Is it the code???? or What??
Any help plz??
BilalD
Re: Problem in a curve drawings
« Reply #1 on: October 20, 2009, 05:46:46 AM »
I am guessing that you have your motors set at the max velocity that they will go and they are both equal in steps per unit.
Lower your velocity to, say 70% of max, and see what happens.
