Hello Guest it is October 21, 2026, 02:54:07 PM
Author Topic: Spindle want run  (Read 13743 times)
Spindle want run
« on: October 15, 2009, 11:27:00 AM »
I downloaded latest upgrade to Smooth Stepper and Mach 3. Now spindle will not run. Tried going back to earlier, but still will not run. Spindle will run from VFD so it is ok. Any suggestions. and I will tell you now I am far from being an expert at this
racear
Re: Spindle want run
« Reply #1 on: October 15, 2009, 12:54:23 PM »
Check in the plugin that you have the correct setting for the type of spindle control, it has probably reset to none.
« Reply #2 on: October 15, 2009, 01:38:17 PM »
Hood thanks for reply. Already thought of that and looked: is on???
racear
« Reply #3 on: October 15, 2009, 02:00:25 PM »
How is your spindle connected, what pins do you need and check they are all still set correctly, also make sure if you use Step/Dir that it is enabled and that any outputs for the spindle have the correct pins set and that the spindle relays if used are not disabled on Spindle Control page  of Ports and Pins.
« Reply #4 on: October 15, 2009, 02:27:01 PM »
Hood. I have a Smooth Stepper pined to a Campbell card. I looked at Outputs and it showed PWM first and I changed it to step/dir but still want run.
racear
« Reply #5 on: October 15, 2009, 03:19:32 PM »
You could try going back to a previous xml.
