Hello Guest it is November 18, 2026, 09:17:53 AM
Author Topic: newbee  (Read 62901 times)
Offline Fastest1
  •  920 920
  • Houston, TX
Re: newbee
« Reply #30 on: October 18, 2009, 01:56:10 AM »
Have you ever run anything cnc? BTW I shouldnt have siaid simple, I should have said cheap. The research to find the answer, well that is different.
Re: newbee
« Reply #31 on: October 18, 2009, 02:00:26 AM »
no nothing on cnc so its all new to me
Offline Fastest1
  •  920 920
  • Houston, TX
Re: newbee
« Reply #32 on: October 18, 2009, 11:30:54 AM »
Well we will be seeing a bunch of each other posts in the near future I am sure. Have you figured out any commands for the MDI box? You can add single line commands.  Cya soon
Re: newbee
« Reply #33 on: October 18, 2009, 11:54:57 AM »
oh thats a bit technical for me at this stage lol
Re: newbee
« Reply #34 on: October 18, 2009, 11:59:05 AM »
Use the stable version of Mach3 (3.042.029)  Version 3.043 has a bug that showed up for me in MDI.  With 3.043, when i set speed (f10) and then typed G1, All three axis started moving.
Re: newbee
« Reply #35 on: October 18, 2009, 12:01:45 PM »
cool thats the version of Mach 3 i have the good one that is
well i'm gonna be busy today trying to work all this stuff out BUT at least we got it movin so thats a start
Offline Fastest1
  •  920 920
  • Houston, TX
Re: newbee
« Reply #36 on: October 18, 2009, 03:22:56 PM »
If you go to the 2nd screen, there is a dialog box at the bottom where you can enter MDI (Manula Data Input). If you type G0 X1 It will travel in the Y positive direction 1" or 1mm whichever unit of measure you have checked. G0 is a rapid movement, G1 a cutting move that also will need a feedrate or it will default to the last speed issued (I think that is the way I understand it. I know it might sound simple if you any experience running a machine, but to those from other fields these movements will be enlightening.
Re: newbee
« Reply #37 on: October 18, 2009, 03:26:25 PM »
thanks man i will try this
Re: newbee
« Reply #38 on: October 18, 2009, 03:43:45 PM »
I love it. You guys are working good together and progressing nicely.  :)
Do you guys know how to post screen shots to get help or help others?
Re: newbee
« Reply #39 on: October 18, 2009, 03:47:27 PM »
Hey Brett
thanks mate, if it wasn't for these guys helping me i would be well you know lol
but in answer to your question no i don't know how to post screen shots
