Hello Guest it is November 22, 2026, 10:13:20 PM
Author Topic: Must X and Y Have Same Acceleration  (Read 11513 times)
« on: October 11, 2009, 10:10:27 PM »
Will there be any problem with using different motor tuning acceleration parameters for the X and Y axis. Just wonder if there would be strange results if, for example, cutting a circle at a high speed or if rounded corners would be asymmetric if Constant Velocity mode is used.
Re: Must X and Y Have Same Acceleration
« Reply #1 on: October 12, 2009, 01:28:15 AM »
You can have different vel and accel on all axis if you like :)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #2 on: October 14, 2009, 05:02:51 AM »
your suspicion that CV will be asymetric is correct. However they have to be quite markedly different before I think you'd notice (depending on your accuracy requirements of course). Personally I prefer to have X and Y accel the same for this reason.
