Hello Guest it is October 15, 2026, 10:31:02 PM
Author Topic: Delay between commands  (Read 9195 times)
« on: September 04, 2006, 05:57:34 PM »
Hi, A couple of questions for the software guys, I've been having
problems with chatter on the end of a cut (see Tangent Corner-
Denford Orac problem)  Since renewing the chuck and trying different
things to solve the problem I have come to realise that there is a
delay when going from a G1 command to a G0 command.
After I have taken a cut and need to back up the tool a bit to rapid
back to take the next cut, the tool just sits there for a bit causing
the tool to rub on the work.
I have changed my G-code listing so that the  G0 rapid off after feed
cut to G1 and there is less of a wait before the next movement.
This has reduced the chatter problem 50%
I'm guessing that this may be due to using a 800mhz computer.
My question is, will increasing processor speed reduce the delay
between commands (G0 AND G1 etc:) and also will increasing the Kernel
speed help.   ???
Many Thanks
