Hello Guest it is November 22, 2026, 02:42:42 PM
Author Topic: Keygrabber jog's only one axe's...  (Read 9989 times)
« on: October 06, 2009, 06:25:22 AM »
Hi. I use keygrabber and a gamepad with two "analog" joysticks, my problem is that i can only jog one axe at a time...
Should it be like that ? With the keyboard i can jog all of them simultaniously...
The gamepad work's perfect when i check it with the controlpanel in windows. It works in Mach3 too, but as i wrote, only one axe at a time...
Sorry for my bad english, but i think u guy's understand.
Thank's from a cold sweden...
Re: Keygrabber jog's only one axe's...
« Reply #1 on: October 06, 2009, 04:22:54 PM »
Olova, you can only do continuos joggin on more than one axis using your set up if I'm not mistaken. Analog jogging is good for only one axis at a time. Maybe this link will help you get what your after.
http://www.machsupport.com/forum/index.php/topic,1391.0.html
