Mach Discussion => General Mach Discussion => Topic started by: olova on October 06, 2009, 07:25:22 AM
Hi. I use keygrabber and a gamepad with two "analog" joysticks, my problem is that i can only jog one axe at a time...
Should it be like that ? With the keyboard i can jog all of them simultaniously...
The gamepad work's perfect when i check it with the controlpanel in windows. It works in Mach3 too, but as i wrote, only one axe at a time...
Sorry for my bad english, but i think u guy's understand.
Thank's from a cold sweden...
Olova, you can only do continuos joggin on more than one axis using your set up if I'm not mistaken. Analog jogging is good for only one axis at a time. Maybe this link will help you get what your after.
http://www.machsupport.com/forum/index.php/topic,1391.0.html
