Hello Guest it is October 21, 2026, 12:10:06 AM
Author Topic: Toolpath view incorrect  (Read 12409 times)
Offline Greolt
  •  956 956
« on: September 25, 2009, 02:34:09 AM »
I think I am right to say this one is a bug.    We will see when someone shows me my error.    ;D
Very simple gcode as follows,
G1 X0 Y0 Z50 A0
A360
Z40
A0
Z30
A360
M30
When the "axis of rotation" is selected as X, in toolpath configuration, the toolpath displays correctly. See pic X-rotation
However when Y is selected, then the toolpath view is not displayed  correctly.  See pic Y-rotation
They should both show three simple rotations of the axis.  As the "X-rotation" pic does.
Any ideas of what silly thing I may be missing.  ;D
Greg
Re: Toolpath view incorrect
« Reply #1 on: September 25, 2009, 08:57:43 AM »
Just curious.  Are you cutting a cylinder?  Calling the "A" axis indicates a 360 turn around one.  No idea why the different rotations would give different pics.   When I post your code to my 4th axis configuration I get a "slice," view of a cylinder being cut to three different depths.  There is no "x" or "y" movement so the cuts are all at "X" 0 and "Y" 0.
Bob@BobsShop
Offline Greolt
  •  956 956
« Reply #2 on: September 29, 2009, 04:13:44 AM »
Yes this toolpath shown is just as simple as can be to demonstrate the problem.
Where I see it is a toolpath to take a rough piece of stock down to a cylinder.
I am not getting much response, so I suppose there are not many doing this sort of rotary axis stuff.
Greg
« Reply #3 on: September 29, 2009, 06:37:33 AM »
I see the exact same thing. Probably should tell Brian on the Yahoo group.
« Reply #4 on: September 29, 2009, 08:36:48 AM »
Yeah.. it is a prblem in the path distance calcs for that plane.. good thing it is just graphics...
Brian
www.newfangledsolutions.com
www.machsupport.com
