Hello Guest it is November 11, 2026, 05:20:01 PM
Author Topic: allen bradley bru 200  (Read 116082 times)
Re: allen bradley bru 200
« Reply #20 on: October 03, 2009, 01:56:36 PM »
Yes I could change and save the parameters that are in the manual, volts per rev , torque mode,  PID etc but no where did I see any way to change the actual motor parameters or commutation parameters.
 Really hope you can find a way to do that.
« Reply #21 on: October 07, 2009, 02:23:57 PM »
Just spent a while on the phone with Rockwell Tech support, they looked all over and cannot find any old Reliance reference to 'Host Mode Protocol' for the BRU-200.
Even got hold of an old Reliance staff member and still no luck.
Ended with a suggestion I buy modern drives!.
Nosmo.
« Reply #22 on: October 07, 2009, 02:32:36 PM »
Ha ! lol......That's what they usually tell me FIRST !
Russ  :D
« Reply #23 on: October 07, 2009, 02:35:17 PM »
See if you can contact Osai in the UK, that is the make of my drives (used to be part or Reliance I think)  and the guy was quite helpful, he may give you the info you need.
« Reply #24 on: June 04, 2012, 04:46:29 PM »
NosmoKing
Did you get anywhere with the BRU drive?
« Reply #25 on: June 04, 2012, 06:39:25 PM »
No, I abandoned  the BRU200 all together.
Nosmo
« Reply #26 on: June 05, 2012, 01:51:09 AM »
I recently bought a BRU 500 and a S6300 motor which I am planning on putting on the spindle of my manual lathe and I decided to get  a Willem programmer so that I could back up the personality module in case of corruption. I can extract the file no probs and can reprogramme the module with the file as well but was hoping I would be able to possibly see some info in it to change the parameters but alas not, its just gobbledegook :(
 I am sure there must be a way to know what each line of the hex file refers to but afraid I cant see anything, maybe there is a manual somewhere that explains it but likely it will be long lost :(
« Reply #27 on: October 05, 2012, 07:20:56 AM »
I saw they need a 24volt input for cw and cww rotatation, am I right?
Cees
Hi, Cees, I saw you have part of the bru-200 manual.
can you be so kind to upload the complete manual or (if not) send it to my mail ? rodmore2 'at' hotmail  'dot' com
I have two of these drives but can't make it work. The mode I like is step/dir, but your piece of atachment shows only analog control (with a pot), just like made in this youtube video: http://www.youtube.com/watch?v=rkgxmzEtVJ0
Did you finally make your drive work ?
« Reply #28 on: October 05, 2012, 07:42:43 AM »
These drives are analogue (-10v to +10v) only so no step/dir capability.
« Reply #29 on: April 03, 2014, 11:17:37 AM »
Cees
please I need documentation of BRU-200, you can give me a download link? thank you
