Hello Guest it is November 18, 2026, 11:53:49 PM
Author Topic: Making an Input do Something  (Read 28635 times)
Offline mhdale
  •  130 130
  • Knowledge is the Treasure.
    • Black Dragon Technologies
« on: September 03, 2006, 12:49:50 PM »
Hello All, I have been trying to get a couple of external inputs to work with my Mach 3 .. with little or no luck. The first is a feedhold button, I have it connected on a second paralell port using one of the CNC4PC new multifunction boards (Nice board BTW) I can see the input working on my diagnostics screen but I cannot get it to do anything. I have tried setting it to hotkey 32 (SPACEBAR) which is the PAUSE button on my screen but it does nothing..... I also have a STOP Button which I want to implement.. again same results... However there seems to be something not quite right with the stop button because I want it to activate the "STOP" button on the screen which is set as hotkey 2131 (ALT S) but when I try and set the Hotkey in my MACH3 inputs screen ALT-S comes up with 2163 not 2131... I have read through the manuals and the Wiki... and am more confused than ever...Any one have a simple step by step on making an external input Trigger an action...either an internal mach 3 function or an external macro?  It all sounded so easy... *grin*
Thanks in advance
Mike
Re: Making an Input do Something
« Reply #1 on: September 04, 2006, 08:12:24 AM »
under Config / system Hot keys enter 1001 into the 1 OEM code edit box. now you need to go to the ports and pins page and set the input to OEM triger #1  There is info in the Wiki that should tell you what number to enter into the OEMcode edt box.
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline mhdale
  •  130 130
« Reply #2 on: September 04, 2006, 10:46:41 AM »
Brian,
Thanks for the reply, but I thinbk I must be one of the few who just cant seem to understand because I still dont "get it". I read through the WIKI and thought that it said to make an external input act like a keyboard button had been pressed to Select the Hotkey you wish the input to trigger and check the emulate field under prots and pins. Is that right? Or do I have to setup an OEM trigger? Is there a simple step by step example of setting up an oem trigger to do something like "feedhold" somewhere which I could examine. I find the Wiki a bit confusing, I am never sure if I am in the right section.
Mike
« Reply #3 on: September 04, 2006, 12:18:45 PM »
Mike set up and OEM trigger... you don't need the Hothey stuff :)
If you do that you should have it working
www.machsupport.com
Offline mhdale
  •  130 130
« Reply #4 on: September 04, 2006, 03:29:29 PM »
Ok Brian,
Is there a Step by Step for doing that??
MIke
« Reply #5 on: September 04, 2006, 04:50:31 PM »
Nope.. you need to dothe step that I gave you in the first message that I posted. Where are you getting stuck? we can get your push buttons running no problem :)
www.machsupport.com
Offline mhdale
  •  130 130
« Reply #6 on: September 04, 2006, 05:04:21 PM »
Ok Brian, I Did as You Suggested.. and Poof it works.... Now... I Allways need to know how something works.... Is there a short explanation?
Offline mhdale
  •  130 130
« Reply #7 on: September 05, 2006, 05:50:16 PM »
Brian, Thanks for your call and all the help you gave... its all working just like i want it to now :)
« Reply #8 on: October 17, 2012, 09:51:07 PM »
Hi Brian, I noticed that you are expert by your replies. I need your help. I want to  use 2 external button to load 2 different Gcode program. I did the macro which load the gcode, but only using screen button, I couldn't do it with my external button. Is that possible? I see some explanation about to create a triggermacro, but my poor understand tell me that it will be working with only one button. well no more talking.... I just want to know how to make 2 external signal(input), button, modbus or else load my gcode and alternate it with a button press.
thanks
darli
« Reply #9 on: October 18, 2012, 01:58:46 AM »
Brian should be an expert, he is the guy that does Mach ;D
On to your question, I messed around with trigger macro a while back and it just didnt work for me, what I did was use Scott Schaefers Mach Mad plugin and that made it easy to set a macro to an external button.
