Hello
Guest
it is
November 19, 2026, 08:17:24 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
Part to Gcode
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Part to Gcode (Read 17130 times)
Ray
70
Part to Gcode
on:
September 19, 2009, 11:35:10 AM »
Can some one please make Gcode from this drawing to make the plate? I will certainly appreciate it. They are absolute values from Point 0,0.. I don't know if the arc would be I,J moves or Radius moves . Thank you so much. Ray
Last Edit: September 19, 2009, 11:41:52 AM by Ray
ger21
6,295
Re: Part to Gcode
Reply #1 on:
September 19, 2009, 12:14:55 PM »
For L1, if you're moving from Y0.5 to Y 2.5, why is the dimension 2.003 instead of 2.000?
Ray
70
Re: Part to Gcode
Reply #2 on:
September 19, 2009, 12:43:00 PM »
I'm sorry for letting that get away without explaining it. The measurements on the drawing are not exact but the ones listed under Absolute: are what I want to use. When I drew it, I didn't enter each measurement I just did a quickie with the mouse. Thanks...Everything is located from 0,0
Last Edit: September 19, 2009, 12:44:36 PM by Ray
ger21
6,295
Re: Part to Gcode
Reply #3 on:
September 20, 2009, 12:48:27 PM »
You left out a lot of details. Feed speed, depth, tool size....
I used cutter comp, for a .25 tool diameter, and .125 deep. For a different diameter tool, change the P value after the G41 to the tools radius.
Ray
70
Re: Part to Gcode
Reply #4 on:
September 20, 2009, 01:03:16 PM »
Ger21, thanks for the assistance. You won't beleive this but I had just finished a modified drawing and was just about to post it when your message came in. Here it is. I need the Arc and I can probably do the next line. Thanks again. I just haven't got the hang of IJ yet.
Ray
70
Re: Part to Gcode
Reply #5 on:
September 21, 2009, 11:52:42 AM »
How do I show Gcode to make this arc please? I donot know about I J moves or if that is the way to do it. From X3.5 Y2.75 to X1.5 Y0.50 with Radius of 2.4 inches. Thanks in advance. Ray
ostie01
628
Re: Part to Gcode
Reply #6 on:
September 21, 2009, 03:17:11 PM »
Try this.
Jeff
ger21
6,295
Re: Part to Gcode
Reply #7 on:
September 21, 2009, 05:59:17 PM »
I already gave you the code for it.
Ray
70
Re: Part to Gcode
Reply #8 on:
September 21, 2009, 06:58:51 PM »
Thank you guys for your assistance. I got input also from Yahoo Group for Mach..and decided to go with the G2 and I J moves. Appreciate your help. PS-Ger21, I dont know exactly why but your code didn't work with Mach2, it was something about Radius to end of arc... Appreciate your help though. Ray
ger21
6,295
Re: Part to Gcode
Reply #9 on:
September 21, 2009, 07:11:29 PM »
Your IJ mode is set to absolute, the code I gave you was incremental.
Print
Pages:
1
Go Up
« previous
next »
