Hello Guest it is November 19, 2026, 08:17:25 AM
Author Topic: Part to Gcode  (Read 17130 times)
Offline Ray
  •  70 70
Part to Gcode
« on: September 19, 2009, 11:35:10 AM »
Can some one please make Gcode from this drawing to make the plate?  I will certainly appreciate it.  They are absolute values from Point 0,0..  I don't know if the arc would be I,J moves or Radius moves .  Thank you so much.  Ray
« Last Edit: September 19, 2009, 11:41:52 AM by Ray »
Re: Part to Gcode
« Reply #1 on: September 19, 2009, 12:14:55 PM »
For L1, if you're moving from Y0.5 to Y 2.5, why is the dimension 2.003 instead of 2.000?
Offline Ray
  •  70 70
Re: Part to Gcode
« Reply #2 on: September 19, 2009, 12:43:00 PM »
I'm sorry for letting that get away without explaining it.  The measurements on the drawing are not exact but the ones listed under Absolute: are what I want to use.  When I drew it, I didn't enter each measurement I just did a quickie with the mouse.  Thanks...Everything is located from 0,0
« Last Edit: September 19, 2009, 12:44:36 PM by Ray »
Re: Part to Gcode
« Reply #3 on: September 20, 2009, 12:48:27 PM »
You left out a lot of details. Feed speed, depth, tool size....
I used cutter comp, for a .25 tool diameter, and .125 deep. For a different diameter tool, change the P value after the G41 to the tools radius.
Offline Ray
  •  70 70
Re: Part to Gcode
« Reply #4 on: September 20, 2009, 01:03:16 PM »
Ger21, thanks for the assistance.  You won't beleive this but I had just finished a modified drawing and was just about to post it when your message came in.  Here it is.  I need the Arc and I can probably do the next line.  Thanks again.  I just haven't got the hang of IJ yet.
Offline Ray
  •  70 70
Re: Part to Gcode
« Reply #5 on: September 21, 2009, 11:52:42 AM »
How do I show Gcode to make this arc please?  I donot know about I J moves or if that is the way to do it.  From X3.5 Y2.75 to X1.5 Y0.50 with Radius of 2.4 inches.  Thanks in advance.  Ray
Re: Part to Gcode
« Reply #6 on: September 21, 2009, 03:17:11 PM »
Try this.
Jeff
Re: Part to Gcode
« Reply #7 on: September 21, 2009, 05:59:17 PM »
I already gave you the code for it.
Offline Ray
  •  70 70
Re: Part to Gcode
« Reply #8 on: September 21, 2009, 06:58:51 PM »
Thank you guys for your assistance.  I got input also from Yahoo Group for Mach..and decided to go with the G2 and I J moves.  Appreciate your help.  PS-Ger21, I dont know exactly why but your code didn't work with Mach2, it was something about Radius to end of arc...   Appreciate your help though.  Ray
Re: Part to Gcode
« Reply #9 on: September 21, 2009, 07:11:29 PM »
Your IJ mode is set to absolute, the code I gave you was incremental.
