Hello Guest it is October 21, 2026, 06:13:34 AM
Author Topic: plasma cutter hookup  (Read 12684 times)
« on: September 14, 2009, 01:30:46 PM »
Hi All
I need help connecting my esab esp 50 to mach 3.  The esp 50 has a cnc interface board with a connection terminal so it should be simple.  But electronics is not my strong suit so I hesitate to experiment.    terminals 1) arc-on signal  2) relay closing signal to cnc  3) start signal  4) relay closing signal from cnc  5) 20:1 (+)  6) voltage divider (-) signal to cnc How hook it up to mach 3?
lynn212
Re: plasma cutter hookup
« Reply #1 on: October 05, 2009, 07:32:12 PM »
I can't believe you didn't get any help, with all the brain power we have on this forum, But , sorry , I,m not one of them.
If your still having problems , I suggest posting in the Mach disscussion post.
Good luck.
Ed
Ed VanEss
