Hello Guest it is October 21, 2026, 03:29:12 PM
Author Topic: Pocketing in LC?  (Read 10847 times)
Offline kolias
  •  1,165 1,165
Pocketing in LC?
« on: September 13, 2009, 03:33:01 PM »
Watching the video LC Pocketing, it says that you create the pocket and then you generate the gcode and send it to Mack3.
But why I should ask LC to create a pocket? If I draw a square in Acad 10”x10”x1/2” thick and then draw another square in the center 4”x4”x1/8” deep (the pocket) and import into Mack3, wouldn’t Mack3 make the cut the way I want it?
I just want to clarify the process in my mind
Nicolas
Nicolas
Re: Pocketing in LC?
« Reply #1 on: September 13, 2009, 09:07:24 PM »
The .dxf file is just lines. You have to tell LazyCAM (or any CAM program) what you want to pocket. It's not smart enough to figure it out on it's own. IN your example, if you just wanted to route two squares, instead of a pocket in a square, you'd still draw it the same, right?
Offline kolias
  •  1,165 1,165
« Reply #2 on: September 13, 2009, 10:39:18 PM »
Of course you are right Gerry….
I guess my thinking is wrong because I didn’t quite understand the meaning of “Pocketing” which probably is a machining terminology. Now I get it
In my example, you are right that Mach will only cut two squares. But if I want the 4”x4” square to be cut at 1/8” deep through all the 4”x4” area, then I have to tell that to LC in the pockets menu.
Thank you for taking the time Gerry
 Nicolas
Nicolas
