Hello Guest it is October 21, 2026, 04:27:29 PM
Author Topic: Rotating work offsets around Y  (Read 35304 times)
« on: September 13, 2009, 12:13:03 AM »
OK, say I'm mounting a rotary table pointing down the X-axis.  By running the mill on top of a piece of stock, I find the diameter is slightly smaller as X increases.  The rotary table is leaning.
I see there is an offset for rotating under MDI, which is the same thing as the G68 offset.  If you set G68 in G-code, it shows up in that window.
The G68 offset can only rotate-about-Z.  The situation described needs to rotate-about-Y.  I don't see any way to do this.  Also, I note that the G68 offset does not have a separate work and machine offset.  Is there no way to separate these?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Rotating work offsets around Y
« Reply #1 on: September 13, 2009, 03:25:04 AM »
It would be a much better solution to square up the rotary table, even if you could use G68 to correct the error you can not compensate for drilling and reaming through the work piece.
Graham
« Reply #2 on: September 13, 2009, 05:30:50 AM »
Graham
Not actually, no.  It's difficult to perfectly square up a rotary table, you'd be shimming back and forth all day and will never be exact.  The logical solution is software, I can easily calculate the exact angular error by top milling, measuring the diameters, and  inverse-sine(delta-radius/delta-X).
Unfortunately the plate I got for mounting the Sherline turned out to be poorly designed.  I've been trying to find one which is better designed.
Drilling and reaming would not be a problem unless phenomenal accuracy were required (and I don't have to drill anyways).  These errors are fairly small, but over a long distance in X the difference in radius can potentially become significant, especially for small-diameter work.
But mainly I'd just like to know how to do it.  I mean, it'd be crazy to have no way to do this.
  •  2,785 2,785
« Reply #3 on: September 13, 2009, 11:11:54 AM »
Wrong again, I will keep my mouth shut from now on.
Everybody wants a quick fix, the skills have gone and nobody wants to set up a machine properly, sad times we live in.
Graham
vmax549
« Reply #4 on: September 13, 2009, 12:26:08 PM »
I am with Graham on this one . IF you can't square your axis in 4 moves or less you need to find a new hobby.
GEEZ does everyone think that computers can solve everything for you to the point you can't do for yourself anymore??
NOT picking on just you the forum is full of request for MACH to FIX their machines so THEY don't have to.
(;-( TP
« Reply #5 on: September 13, 2009, 12:54:08 PM »
There is no method I'd ever even seen SUGGESTED for precision mounting of a Sherline rotary table on a Taig.
When it goes on, yes, it's "basically" squared up.  But again, small errors become larger as X increases.
What I actually ran into is, I've got the plate from High Tech Systems LLC:
This works, but it's got a flaw that keeps it from being "precision".  This only attaches to the table via two screws offset to the back (the other holes cannot be used).  Only one side of the plate.  As you tighten them down, the front rises.  I know, I could fit a sheet of paper under the other side of the plate.  So no matter what you do, the front will rise from zero as soon as you start applying pressure.
I could try to come up with some micro-thin, stiff shimming material to go between the Sherline and the plate to bias it down to begin with, then somehow measure and control the screw force.  But this doesn't seem like a good idea, for one, it might be hard to get a particular correction value from screw force by hand, two, the screw force is necessary to hold it down and there's only a limited room for leeway in how tight you can make it.
vmax549
« Reply #6 on: September 13, 2009, 01:55:45 PM »
OBVIOUSLY the surface is NOT flat (;-) IF you fix the machine you only have to fix it ONCE. IF you rely on software you will have to correct it every time you remount the 4th axis.
NOW for the softawre fix if you look in config and then down to axis formulas there is a math channel you can used to do corrections AS LONG as the corrections are linear in nature it will work.
Just a thought, (;-) TP
« Reply #7 on: September 13, 2009, 01:59:38 PM »
MechanoMan, could you attach a photo of your setup?  Since you're mounting your table with axis parallel to Y I don't see why you couldn't make a mounting plate that extends past the base of the Sherline table far enough to put a screw in a second t-slot in the Taig's table and stiffen up the mounting?
Randy
« Reply #8 on: September 13, 2009, 02:10:15 PM »
Randy
Yeah I might make something like that.  IIRC, I saw a Sherline mount like that for sale somewhere.  The problem is that when the Sherline jaws are extended for large work, they need clearance all the way to the table.  If this was to work, it'd need to be sort of a wide "H" shape to allow clearance underneath it.
But it'll never be adjustable, not that I'd expect large errors anymore, but there would always be an error.  I don't understand the animosity for me wanting a software solution.  Attempting to true up the hardware itself looks extraordinarily difficult crapshoot of a process, and probably the worst way to go about doing this.  Setting the angle from calculations should be fully accurate in one shot.  True, if you bored a hole it wouldn't be perfectly perpendicular but it a really trivial way.
« Reply #9 on: September 13, 2009, 02:32:23 PM »
OK yeah that's the one I was thinking of.  It's made by Cartertools.  But I don't see how that's gonna work.  When you add a chuck, the jaws extend way out when fitting large work.  I'm only eyeballing it but it looks like the plate and screws are under the area that the jaws will extend into.
