Hello Guest it is October 21, 2026, 12:07:42 PM
Author Topic: New to routing need help with letters  (Read 12199 times)
« on: September 11, 2009, 05:02:45 PM »
I'm very new to routing but have experience running a vinyl cutter.
We've got our router up and running and have cut out a few words using lazycam/mach3
The issue were having is the router is rounding parts of letters that should be a 90 degree corner,  such as the corners on the top of an upper case L.
I'm not sure where to start with this problem if anyone has any suggestions I would greatly appreciate it.
Tyler
Re: New to routing need help with letters
« Reply #1 on: September 11, 2009, 06:04:12 PM »
vmax549
« Reply #2 on: September 13, 2009, 02:22:25 PM »
ARE you actuall cutting the letters or just looking at the toolpath generated?
« Reply #3 on: September 14, 2009, 09:11:56 AM »
cutting the actual letters,  the tool paths all look right with good corners but when cut the corners get rounded.. this is my first day at work since I made the post so I'm gonna try some of the settings sam suggested
