Hello Guest it is October 17, 2026, 07:52:46 PM
Author Topic: Reversing axis coordinates  (Read 11985 times)
« on: September 09, 2009, 09:57:57 AM »
I have retrofitted a Bridgeprt mill with Mach3 and Mitsubishi servos. My controller has a manual pulse generator, and I would like the handwheels on the mill to turn the same direction that it does. But when I get the wheel on the Y axis to turn clockwise when the MPG is turned clockwise, it reads as positive movement. I want it to read as negative movement. I can get it to move in the right directions, but then the handwheel is reversed from the MPG. Basicly, I think I want to reverse my axis without reversing my motors. Does that make sense and can anyone help me out?
Offline mr.c
  •  40 40
Re: Reversing axis coordinates
« Reply #1 on: September 09, 2009, 11:18:08 AM »
I think that you can go to your configuration (ports and pins) and reverse the pin assignments for a and b.
« Reply #2 on: September 09, 2009, 11:48:45 AM »
I've gone to Encoder/MPG in ports and pins. But all the a and b values in there are zero, so I can't really switch them. What am I missing?
Offline mr.c
  •  40 40
« Reply #3 on: September 09, 2009, 11:59:36 AM »
I was assuming that your MPG was wired to a parallel port which would require port and pin assignments. I assumed wrong. It will probably require swappng connections to your controller. But don't go by this assumption. Perhaps someone else will have a definitive answer.
