Hello Guest it is October 21, 2026, 10:57:37 AM
Author Topic: mach3 bahaves badly  (Read 16969 times)
Offline Robhi
  •  138 138
mach3 bahaves badly
« on: September 06, 2009, 02:36:03 PM »
hello,
 I have some problem when turning wood with my mach3..
I programme M piecework with maystercam design, sometimes I use circle to get some kind of shapes to make my piecework.. then I delete the half of the circle for example.etc... but the problem is mach3 sees always the circle but not as arcs, and once it cuts completely my piecework.
anybody know where the problem is?
thanks Robhi
Re: mach3 bahaves badly
« Reply #1 on: September 06, 2009, 04:50:53 PM »
Can you post a screenshot of the toolpath, could be a few things, first is your IJ mode, second could be reversed arcs in front toolpost and possibly even you need a G2 rather than a G3 or vice versa.
Offline Robhi
  •  138 138
« Reply #2 on: September 07, 2009, 02:11:36 PM »
Hello, thanks for replying..
Here is a screenshot as well as a copy of mach3 turn XML.
But I have know idea about:-
Robhi
Thanks again
Robhi
« Reply #3 on: September 07, 2009, 02:51:40 PM »
can you also post your code please.
Offline Robhi
  •  138 138
« Reply #4 on: September 08, 2009, 01:22:37 PM »
Hello,
attached is the file of the workpiece.
Robhi
« Reply #5 on: September 08, 2009, 01:39:29 PM »
Config menu, Ports and Pins, Turn Options and take the check out of Reversed Arcs in Front  Toolpost and see it it looks right.
Offline Robhi
  •  138 138
« Reply #6 on: September 08, 2009, 03:12:43 PM »
hello,
Thanks Hood, I will try as you said and let you of course.
thanks
Robhi
Offline Robhi
  •  138 138
« Reply #7 on: September 10, 2009, 11:37:08 AM »
hello,
Thank you too much for your help, everything is OK..
Thanks Hood and all of you.
Robhi
« Reply #8 on: September 10, 2009, 12:14:57 PM »
