Mach Discussion => General Mach Discussion => Topic started by: Robhi on September 06, 2009, 03:36:03 PM
hello,
I have some problem when turning wood with my mach3..
I programme M piecework with maystercam design, sometimes I use circle to get some kind of shapes to make my piecework.. then I delete the half of the circle for example.etc... but the problem is mach3 sees always the circle but not as arcs, and once it cuts completely my piecework.
anybody know where the problem is?
thanks Robhi
Can you post a screenshot of the toolpath, could be a few things, first is your IJ mode, second could be reversed arcs in front toolpost and possibly even you need a G2 rather than a G3 or vice versa.
Hello, thanks for replying..
Here is a screenshot as well as a copy of mach3 turn XML.
But I have know idea about:-
RobhiCan you post a screenshot of the toolpath, could be a few things, first is your IJ
Thanks again
Robhi
can you also post your code please.
Hello,
attached is the file of the workpiece.
Robhi
Config menu, Ports and Pins, Turn Options and take the check out of Reversed Arcs in Front Toolpost and see it it looks right.
hello,
Thanks Hood, I will try as you said and let you of course.
thanks
Robhi
hello,
Thank you too much for your help, everything is OK..
Thanks Hood and all of you.
Robhi
