Hello Guest it is October 21, 2026, 10:51:03 AM
Author Topic: Can you stop release on outside jogging  (Read 18445 times)
« on: August 31, 2006, 12:35:18 PM »
Hi
When using my touch screen I've noticed if you press a jog button then move your finger off the button before releasing, the axis caries on jogging till you press and release the button again. While I can see the advantage of this for manual machining, I've also experienced the downside of it having my tool rapid straight into my job and not being quick enough to stop it, luckily it was only a wooden test piece.
Is there a way of disabling this function or changing it so it only does it on a double click or something?
Chris
Re: Can you stop release on outside jogging
« Reply #1 on: August 31, 2006, 08:31:46 PM »
This is a known bug and we are looking into it now :)
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline Glenn
  •  129 129
« Reply #2 on: September 02, 2006, 05:57:10 PM »
Hi Chris,
    Is a touch screen a special kind of screen, or can any screen work with the right programs?
Thanks, :D
Glenn
Don't assume anything.....it'll make a Manager out of U and Me!
« Reply #3 on: September 02, 2006, 09:10:40 PM »
BTW this problem is now fixed for he next release  :o
Yes any touch screen should work fine
www.machsupport.com
« Reply #4 on: September 03, 2006, 02:37:15 AM »
Hi Chris,
Thanks, :D
Glenn
You can convert a normal screen to a touch screen by buying an overlay panel that goes on to of the screen or you can buy one that was designed from the start as a touch screen. There are two main kinds of touch panels, resistive and capacitive, everyone recommends resistive as I think the capacitive are supposed to give problems with coolant and oil covered fingers. However I bought a capacitive and have been using it for maybe 6 months now and never had a problem other than having to clean the screen every now and then to wipe away the layer of oily, grimy fingerprints ;)
Heres a link to the addon panels http://www.magictouch.com/addon.html
Offline Glenn
  •  129 129
« Reply #5 on: September 03, 2006, 03:00:19 PM »
Neat!
It looks like it is easier than a mouse,  :)
Thanks for the link Hood.
Glenn
« Reply #6 on: September 03, 2006, 05:11:44 PM »
Thankyou very much Brian
Glenn they really are easier than trying to use a mouse and there a lot quicker too, I picked my touch screen up for £36 on Ebay, it's old and only has a 12" screen with poor colours but I like it. Like Hoods mines a capacitive type, not had any trouble with it but have noticed it won't work if you don't use your fingers i.e. nothing happens if you press on the screen with a piece of plastic so I guess it won't work if you wear gloves.
Chris
« Reply #7 on: September 12, 2006, 12:47:35 PM »
Thanks Brian, the latest version works a treat.
« Reply #8 on: September 13, 2006, 05:53:45 PM »
Great it is nice to keep people happy :)
www.machsupport.com
