Hello Guest it is September 12, 2026, 03:52:21 AM
Author Topic: LAZYCAM - DEFINITON OF ANY TERM IN THE MANUAL  (Read 261504 times)
« on: August 30, 2009, 04:49:38 PM »
Hi All LC users,
Sometime in the future the manual will have an appendix which will define any terms you may not understand.
So please post here and over time it will get done based on what is posted here.
Appreciate it,
Re: LAZYCAM - DEFINITON OF ANY TERM IN THE MANUAL
« Reply #1 on: September 23, 2009, 11:38:50 AM »
Hello i tried to use lazycam with a plasma and have some problèms with the terms:
referencing distance ? is it for the size of the plasma exp 1.2 or 0.8
reduction radius ?
pierce delay ?
lift delay
Many thanks for answer on this plasma part of lazy cam
« Reply #2 on: September 23, 2009, 03:18:03 PM »
Sorry, but the manual dosen't cover the Plasma Module . I missed saying that in section 2.1
I don't know much about plasma cutting. If someone wants do that module I will surely add it.
« Reply #3 on: January 17, 2011, 08:01:42 AM »
Is there a manual?
I'm returning from an long hiatus, I'm actually falling in love with LC all over again, simple milling.
Terms:
Under Posting Options, what is "Plunge Clearance"?
"LeadIn"?
what is "Overhang" when creating pockets?
Thanks, Curtis
« Reply #4 on: January 17, 2011, 03:51:20 PM »
Is there a manual?
Yes, in Members Docs
See Tutorial #6 (page 100) in the manual
"LeadIn"?
How the tool will move in preparation for a cut, required in some cases, see Tutorial #7, page 113 in the manual
also section 8.4.2
Not required or functional from what I could figure out when hacking the program
« Reply #5 on: January 18, 2011, 03:00:41 PM »
Thanks Rich, nice to have a manual, looks really good.
Offline kolias
  •  1,165 1,165
« Reply #6 on: March 28, 2011, 08:21:08 AM »
Regarding Tutorial #4, what is the difference between Raised Text and Relief Cut?
Nicolas
« Reply #7 on: March 29, 2011, 04:49:43 AM »
Nicolas,
I was thinking that text letters would be above a surface thus raised or below a surface thus in relief.
When engraving you taper in the material around the text and I was taught it was in relief.
LC does not generate code for relief in the true sense since your just machining the text so it sits above the bottom of a pocket.
Offline kolias
  •  1,165 1,165
« Reply #8 on: March 29, 2011, 08:16:25 AM »
Much appreciate your time RICH
In my mind I thought that both above and below the surface will be raised text since in both cases you have to make a pocket or offset around the text.
Now I got it, thanks again
Nicolas
« Reply #9 on: June 12, 2011, 07:16:03 PM »
I loaded lazy cam and used it.  I inported a dxf file.  it change the finish demintion and couldn't keep the size 1 to1.  need help.
Tim
