Hello Guest it is November 23, 2026, 09:57:38 PM
Author Topic: Current Kernel Speed  (Read 15855 times)
Offline kolias
  •  1,165 1,165
« on: August 27, 2009, 03:36:59 PM »
Yesterday I adjusted the current on my 3 drives according to manufacturer specs for 3.0A motors, set the steps per to 32000 (1/16 microstep), velocity to 50 and accl to 7. Then I did some drawings with the machine and all worked well.
Today I started the machine this morning and got this message when I fired up mach; "Warning one or more axis are tuned too fast for current Kernel speed of 25000"
What this message means?
Should I decrease the microstep to 1/8 or ?
Nicolas
Nicolas
Re: Current Kernel Speed
« Reply #1 on: August 27, 2009, 03:44:18 PM »
Increase the Kernel and see if your computer is happy with it, you should manage 45KHz. You change it on Ports and Pins main page.
Offline kolias
  •  1,165 1,165
« Reply #2 on: August 27, 2009, 03:55:26 PM »
I will do that Hood, thanks
Nicolas
Nicolas
Offline kolias
  •  1,165 1,165
« Reply #3 on: August 28, 2009, 12:15:09 PM »
Guess the computer was happy at 45KHz but not the machine, got one or two motors stalling. So I decrease the step from 1/16 to 1/8 change the other settings accordingly, change the Kernel back to 25KHz, reboot and now all is fine.
Nicolas
Nicolas
