Mach Discussion => General Mach Discussion => Topic started by: kolias on August 27, 2009, 04:36:59 PM
Yesterday I adjusted the current on my 3 drives according to manufacturer specs for 3.0A motors, set the steps per to 32000 (1/16 microstep), velocity to 50 and accl to 7. Then I did some drawings with the machine and all worked well.
Today I started the machine this morning and got this message when I fired up mach; "Warning one or more axis are tuned too fast for current Kernel speed of 25000"
What this message means?
Should I decrease the microstep to 1/8 or ?
Nicolas
Increase the Kernel and see if your computer is happy with it, you should manage 45KHz. You change it on Ports and Pins main page.
I will do that Hood, thanks
Nicolas
Guess the computer was happy at 45KHz but not the machine, got one or two motors stalling. So I decrease the step from 1/16 to 1/8 change the other settings accordingly, change the Kernel back to 25KHz, reboot and now all is fine.
Nicolas
