Hello Guest it is October 21, 2026, 07:56:08 AM
Author Topic: Circular pocket problems  (Read 36015 times)
« on: August 27, 2009, 03:19:35 PM »
I've come across a small problem with the circular pocket wizard. When generating the wizard and previewing, everything looks fine. When posting, the G-code changes slightly, causing an "uneven" spiral. Attached image captures show the problem. The unevenness causes chip load to vary.
Suggestions?
-brian
Re: Circular pocket problems
« Reply #1 on: August 27, 2009, 08:17:31 PM »
brian,
Can you post screen shot of the inputs / settings you are using in the Circular Pocket by Brian Barker.
I don't get that.
« Reply #2 on: August 27, 2009, 08:39:26 PM »
Simple 3/4" pocket at 0,0. Using a 1/4" tool.
Using newest Mach Version R3.042.029, but was having similar problems with older versions.
-bri
« Reply #3 on: August 28, 2009, 07:49:26 AM »
brian,
Thanks, now i get the same as you.
Change your % step over from 15 to 50%.
BTW, Your using NF Solutions Wizard and there is an updated version. Not sure if that version did anything with
that particular wizard.
« Last Edit: August 28, 2009, 07:52:47 AM by RICH »
« Reply #4 on: August 28, 2009, 05:04:15 PM »
Yes, later versions did fix some circular pocket problems.
Note there is a Change.log file in the folder with the wizards .set file that I try to keep up on any changes I make.
« Reply #5 on: August 29, 2009, 10:14:29 AM »
I've upgraded to the newer version, but the problem is still there.
Though the problem only seems to arise at certain % step-overs. %40 and %50 both seem alright.
-bri
« Reply #6 on: August 29, 2009, 10:37:20 AM »
The wizard applies no intelligence to your choice of stepover, so I guess the only solution is to use values that work to your satisfaction.
