Hello Guest it is October 20, 2026, 03:01:36 PM
Author Topic: Anahiem ac servo, compatible with Mach3??  (Read 11029 times)
« on: August 26, 2009, 12:27:39 PM »
Hi
Does anybody know if you can hook up a servo driver from Anahiem Automation and/or how to hook it up?
Will it work with Mach3?  I have the system wired up and can jog off the servo drive but Mach 3 isn't doing anything.
Josh Learman
http://www.anaheimautomation.com/products/servo/servo-drives-controllers.php?vTID=125
Re: Anahiem ac servo, compatible with Mach3??
« Reply #1 on: August 26, 2009, 12:48:31 PM »
Have you got the Step/Dir ground wire connected to your BOBs gnd?
« Reply #2 on: August 26, 2009, 12:57:03 PM »
Hi Hood thanks for the help
I do Have it grounded correctly. I have a 2 systems using an Anaheim stepper drivers and they work great.  My next system I wanted to step things up a bit and get a servo system up and running. The rep at Anaheim asked if i checked my signal on a oscilloscope to verify i was getting a square wave and 50% duty cycle.
« Reply #3 on: August 26, 2009, 03:01:13 PM »
If you definitely have the wiring correct and the drive is getting the pulse then it has to be a config in the drive. Do you have the drive enabled?
