Hello Guest it is November 25, 2026, 11:33:03 PM
Author Topic: cant get reset button to turn off  (Read 11695 times)
« on: August 23, 2009, 09:45:10 AM »
I downladed the new nversion of mach last night. For some reason i cant get the reset button off so i can run my gcode,so i downloaded the older version still haveing problems with it. whats wrong with it?
thanks alex
Re: cant get reset button to turn off
« Reply #1 on: August 23, 2009, 09:53:15 AM »
Go into config>ports & pins>input signals and enable the ESTOP mine is just emulated.
« Reply #2 on: August 23, 2009, 10:45:12 AM »
checked on and off did not work either way?
alex
« Reply #3 on: August 23, 2009, 11:12:07 AM »
Look on the diagnostics page and see if any of the limit LEDs are active. If they are then check in Ports and Pins to see you have them set right. If you dont have limit switches then disable them in Ports and Pins. If you do have limits and they are set right then check that the actual switches are not activated or wiring come loose.
Failing that attach your xml and we can have a look to see if there is a problem with it.
