Mach Discussion => General Mach Discussion => Topic started by: alex850 on August 23, 2009, 10:45:10 AM
I downladed the new nversion of mach last night. For some reason i cant get the reset button off so i can run my gcode,so i downloaded the older version still haveing problems with it. whats wrong with it?
thanks alex
Go into config>ports & pins>input signals and enable the ESTOP mine is just emulated.
checked on and off did not work either way?
alex
Look on the diagnostics page and see if any of the limit LEDs are active. If they are then check in Ports and Pins to see you have them set right. If you dont have limit switches then disable them in Ports and Pins. If you do have limits and they are set right then check that the actual switches are not activated or wiring come loose.
Failing that attach your xml and we can have a look to see if there is a problem with it.
