Hello Guest it is October 20, 2026, 03:04:35 PM
Author Topic: gCode I & J  (Read 19247 times)
Offline kolias
  •  1,165 1,165
gCode I & J
« on: August 22, 2009, 10:50:47 PM »
I made this simple drawing and got the gcode with Lazycam
Is it easy for someone to explain what the I and J means on the code?
I only know what X Y & Z means
Nicolas
Nicolas
Offline kolias
  •  1,165 1,165
Re: gCode I & J
« Reply #1 on: August 22, 2009, 10:56:55 PM »
Very sorry, I found the answer
Nicolas
Nicolas
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: gCode I & J
« Reply #2 on: August 23, 2009, 08:29:40 AM »
Can you please explain what you found? Very often other folks will search old messages when they have a similar question and your findings may be a valuable resource for them.
Happy machining , Jeff Birt
Re: gCode I & J
« Reply #3 on: August 23, 2009, 08:33:50 AM »
he probably just clicked the G Code button in Mach.
Offline kolias
  •  1,165 1,165
Re: gCode I & J
« Reply #4 on: August 23, 2009, 09:07:22 AM »
Right on Hood, this button has tons of info
Nicolas
Nicolas
Re: gCode I & J
« Reply #5 on: August 23, 2009, 09:13:55 AM »
The Mach3 Turn - Arc Motion write up in Members Docs provides definiton and has examples of arcs in different positions. For the lathe but still basic good info that you can adjust for the mill.
Offline kolias
  •  1,165 1,165
Re: gCode I & J
« Reply #6 on: August 23, 2009, 01:43:30 PM »
What is Members Docs?
Nicolas
Nicolas
Re: gCode I & J
« Reply #7 on: August 23, 2009, 01:54:00 PM »
Nicolas
http://www.machsupport.com/forum/index.php/board,78.0.html
Offline kolias
  •  1,165 1,165
Re: gCode I & J
« Reply #8 on: August 23, 2009, 02:23:39 PM »
Thank you Hood, nice to know about all this docs
Nicolas
Nicolas
