Hello Guest it is November 13, 2026, 05:55:30 PM
Author Topic: How to use 0-3.3 volt analog output to control 0-10 Volt VFD ?  (Read 21114 times)
I don't know what circuit or device to use to interface the Pokeys analog output to a 'standard' VFD. The VFD requires 0-10 Volts to go from stopped to full speed.
Thanks in advance !
CNC4PC has a model C14 0-5 volt converter which can deliver a output of 0-10 volts  , (For only $12.28) , but my pokeys unit only goes to 3.3 volts ?
« Last Edit: August 13, 2009, 08:48:13 AM by RadiantHeat »
Offline borisz
  •  220 220
    • www.poscope.com
Re: How to use 0-3.3 volt analog output to control 0-10 Volt VFD ?
« Reply #1 on: August 13, 2009, 09:49:14 AM »
Hi!
Ask Arturo from CNC4PC what should be changed for 0-3.3V input.
regards
Boris
« Reply #2 on: August 13, 2009, 06:33:59 PM »
if you VFD (check you programming manual), it may have an Analog Offset that you can scale to the 3.3
scott
« Reply #3 on: August 18, 2009, 04:51:19 AM »
Just a small-signal PNP transistor with a 10-12 volt external power source should do the trick. NTE 59 or equiv. should do it.
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #4 on: August 18, 2009, 05:14:54 AM »
Transistor is not linear at it ewill not do the work correctly.
CNC4PC has a model C14 0-5 volt converter which can be adjuste for 3,3 V.
