Third party software and hardware support forums. => PoKeys => Topic started by: RadiantHeat on August 13, 2009, 09:25:07 AM
I don't know what circuit or device to use to interface the Pokeys analog output to a 'standard' VFD. The VFD requires 0-10 Volts to go from stopped to full speed.
Thanks in advance !
CNC4PC has a model C14 0-5 volt converter which can deliver a output of 0-10 volts , (For only $12.28) , but my pokeys unit only goes to 3.3 volts ?
Hi!
Ask Arturo from CNC4PC what should be changed for 0-3.3V input.
regards
Boris
if you VFD (check you programming manual), it may have an Analog Offset that you can scale to the 3.3
scott
Just a small-signal PNP transistor with a 10-12 volt external power source should do the trick. NTE 59 or equiv. should do it.
Transistor is not linear at it ewill not do the work correctly.
CNC4PC has a model C14 0-5 volt converter which can be adjuste for 3,3 V.
