Hello
Guest
it is
November 10, 2026, 02:23:26 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
VB and the development of wizards
Toggle ON/OFF output VB Script?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Toggle ON/OFF output VB Script? (Read 16850 times)
robertmonroe
23
on:
August 12, 2009, 08:20:28 PM »
I made a screen where I have buttons for the outpus so I need to toggle them on and off.
What would be the VB Script for output 1 for example?
ger21
6,295
Re: Toggle ON/OFF output VB Script?
Reply #1 on:
August 12, 2009, 09:32:38 PM »
http://www.machsupport.com/MachCustomizeWiki/index.php?title=Mach_specific_Subroutines/Functions_grouped_by_purpose#Input.2FOutput_signals.2C_Modbus_I.2FO.2C_a_serial_port_and_.22foreign.22_ports
robertmonroe
23
Reply #2 on:
August 13, 2009, 12:43:11 AM »
Could I get a sample VB Script? For toggling an LED too.
Please, thanks in advance.
Robert
ger21
6,295
Reply #3 on:
August 18, 2009, 09:17:57 PM »
What outputs are using? And how are you using them?
Grand Master B
19
Reply #4 on:
October 30, 2009, 06:31:39 AM »
button code:
If IsOutputActive(OUTPUT6) Then
DeActivateSignal(OUTPUT6)
else
end if
LED code:
and if you want an LED to go on and off with the button select (Output 6 Active LED) for that LED
(OEM code 79) for output 6
howajo
1
Reply #5 on:
March 15, 2014, 12:31:08 AM »
Just found this snippet of script which totally solved my problem, thanks!
Print
Pages:
1
Go Up
« previous
next »
