Hello Guest it is November 10, 2026, 01:57:29 AM
Author Topic: Toggle ON/OFF output VB Script?  (Read 16844 times)
« on: August 12, 2009, 08:20:28 PM »
I made a screen where I have buttons for the outpus so I need to toggle them on and off.
What would be the VB Script for output 1 for example? ???
Re: Toggle ON/OFF output VB Script?
« Reply #2 on: August 13, 2009, 12:43:11 AM »
Could I get a sample VB Script?  For toggling an LED too.
Please, thanks in advance.
Robert
« Reply #3 on: August 18, 2009, 09:17:57 PM »
What outputs are using? And how are you using them?
« Reply #4 on: October 30, 2009, 06:31:39 AM »
button code:
If IsOutputActive(OUTPUT6) Then
DeActivateSignal(OUTPUT6)
else
end if
LED code:
and if you want an LED to go on and off with the button select (Output 6 Active LED) for that LED
(OEM code 79) for output 6
« Reply #5 on: March 15, 2014, 12:31:08 AM »
Just found this snippet of script which totally solved my problem, thanks! :D
