Hello Guest it is November 22, 2026, 06:04:50 PM
Author Topic: Now What! Jog says mm - Gcode say G21 - machine moving in inches  (Read 15505 times)
I'm about to start questioning my intelligence. My units are mm? The jog display says mm. I have g21 in the code. So what magic switch did I forget to throw?
G80 G21
G0 Z0.26
G0 X-0.26
F25
G0 X0.25
G1 Z-14.95 <-- tries to move to -15" here!
G0 X-0.01 Z-14.74
G0 Z0.26
G0 X0.5
G1 Z-14.95
G0 X0.24 Z-14.74
G0 Z0.26
Re: Now What! Jog says mm - Gcode say G21 - machine moving in inches
« Reply #1 on: August 12, 2009, 07:31:03 AM »
Please attach your xml.
« Reply #2 on: August 12, 2009, 07:46:13 AM »
I do appreciate your help and I know this is the best value I have found in many years of hobby (or professional) cnc.
« Reply #3 on: August 12, 2009, 01:02:34 PM »
Presuming you have this working now as your other thread seems to say you are threading correctly.
Had a look at the xml and it seemed fine and seemed to work fine here.
« Reply #4 on: August 12, 2009, 01:48:32 PM »
No, actually this is a boring move. I just found out I've been using an unlicensed copy in the shop. Would that matter? I can check again.
« Reply #5 on: August 12, 2009, 01:56:17 PM »
I did notice you had the Y axis enabled in Turn, most people dont have a Y on their lathe so if you dont disable it. Probably not the problem but worth doing anyway.
