Hello Guest it is October 21, 2026, 06:28:02 AM
Author Topic: metric readings in centimetres.  (Read 11134 times)
« on: August 10, 2009, 10:10:18 AM »
Hi, i'm in the process of converting a denford novamill to mach3. Everything is progressing well, but i've noticed a small point that doesn't seem right. The readings seem to be in centimetres rather than millimetres. Can this be changed, and i'm in the demo version at the moment does that make a difference.
Re: metric readings in centimetres.
« Reply #1 on: August 10, 2009, 10:14:28 AM »
Sounds like you have your steps per mm set incorrectly in motor tuning.
« Reply #2 on: August 10, 2009, 10:20:52 AM »
sorted, thanks. ;D
