Hello Guest it is November 01, 2026, 11:53:02 AM
Author Topic: Galil PostProcessor  (Read 10786 times)
Galil PostProcessor
« on: August 08, 2009, 12:40:50 PM »
Hello there,
Does anyone know if there is a Galil PostProcessor for LazyCam?
Thanks.
Aldemar
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Galil PostProcessor
« Reply #1 on: August 09, 2009, 04:58:03 AM »
Hi, Aldemar
Not sure what your looking for, Lcam's post will work with Mach3 software with a Galil card's 3 axis, Is it your looking for 4th/5th... axis support, Any movement like that would require editing G code or a Cam package supporting additional axises.
Chip
« Reply #2 on: August 09, 2009, 08:49:19 AM »
Hello Chip,
Thank for your reply.
I read that Mach3 works with Galil Controllers. If I have a dxf/dwg file (with some arcs and lines), Is Lazycam able to generate Galil native languaje?
I am not sure if it is possible to execute a GCode File using Mach3 software and a Galil Controller or if it is neccesary to use the Galil languaje (those commands begin with two letters) ...
This is my concern...
Best regards,
Aldemar Martin B.
Offline kcrouch
  •  193 193
  • In way too deep!!!
« Reply #3 on: August 09, 2009, 09:24:20 AM »
Please look at the Galil plugin on the Mach web site under downloads -> plugins. There is the latest Galil plugin along with a manual available for free.
Kenny
Having way too much fun! Something must surely be wrong.
vmax549
« Reply #4 on: August 09, 2009, 10:23:15 AM »
Mach is the Motion interpetor .    The gcode tells MACH what to do, then mach interputes that into galil and sends it to the galil for motion processing.
So all you need is the Mach3 post to generate correct Gcode.
Hope that helps, (;-0 TP
