Hello
Guest
it is
November 22, 2026, 08:23:19 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Charge pump setting THC300
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Charge pump setting THC300 (Read 15718 times)
Kees Holland
6
on:
August 26, 2006, 12:12:06 PM »
I setup my THC300 and the most settings are working only the torch on doesn't work
my pin settings are port2 pin1 as the manual says now i read some thing about the
charge pump settings is that my problem?
Best regards, from the Netherlands
Logged
Best regards, Kees
Brian Barker
3,860
Re: Charge pump setting THC300
Reply #1 on:
August 27, 2006, 03:14:22 PM »
The cherge pump could be the problem... This is used by many to enable boards... I don't have a THC so I can't help to much
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
jcullins
11
Reply #2 on:
September 26, 2006, 08:33:41 AM »
The 2nd charge pump must be set to port2 pin 17. This will prevent turning on the torch until
Mach is reset.
JIM
Logged
mrpeja
114
Reply #3 on:
March 01, 2009, 05:35:44 AM »
Hi Jim,
I was wondering what is Charge pump2 for. Now I found this topic.
Does it means THC300 Logic board has circuit to prevent Torch output to be activated, or what?
I just have buy my Mach3 licence, and I want to build my own THC device.
mrpeja
Logged
jcullins
11
Reply #4 on:
March 01, 2009, 07:03:01 AM »
Yes. The charge pump out from Mach is a tone about 13khz or so. We use this output to know when Mach is ready to cut.
It enables the Torch trigger relay out only when Mach has been reset and ready to run . It is on charge pump2 port 2 pin 17
You can download the manual from
www.soundlogicus.com
click on support/download.
Jim
Logged
mrpeja
114
Reply #5 on:
March 01, 2009, 07:48:42 AM »
Thanks Jim,
I understand now this function and can implement it to my hardware.
I posted more questions in General Mach Discussion, under the name "THC300 Port pins usage", please Jim replay to.
mrpeja
Logged
Print
Pages:
1
Go Up
« previous
next »
