Hello Guest it is October 25, 2026, 05:54:19 AM
Author Topic: GRIFFIN POWERMATE  (Read 39331 times)
GRIFFIN POWERMATE
« on: August 04, 2009, 05:10:11 AM »
Greetings "O" cnc gods!
ive just installed my griffin powermate into mach3..It show the axis change in the STATUS bar ...but no movement in th DRO'S please help!
Thanx
Haydn
« Last Edit: August 04, 2009, 10:10:53 AM by bladerunner »
Re: GRIFFIN POWERMATE
« Reply #1 on: August 05, 2009, 08:53:40 PM »
HELP PLEASE ANYBODY!
looks like this thing is a LEMON! :(
Haydn
« Reply #2 on: August 05, 2009, 09:02:06 PM »
Haydn,
Never heard of a Griffin Powermate, don't know if it's an apple or a lemon!  ;)
Maybe you can provide somemore info on it or how it installs into MACH.
« Reply #3 on: August 05, 2009, 10:03:04 PM »
howdee!
I found the thing in the plugins directory and hoped it would be usefull as its a jog wheel it installs ok when i press the wheel down to change axis..cool but when i rotate the wheel no indication in the DRO,s that its working...use the arrow keys and the DRO,s show movement!
so the lemon is a lemon!
HAydn
« Reply #4 on: August 05, 2009, 10:27:29 PM »
Well not totally. If it uses an encoder then the encoder can be wired to make an MPG via the PP.
What plug-in directory are you referring to?
« Reply #5 on: August 05, 2009, 10:45:10 PM »
HAYDN,
Well, egg on my face !  :) ??? ;) ;D
Can't help you out as i never used that one and just never took notice to it in the PlugIn's.
Surely someone in here must have used it and will post.
« Reply #6 on: August 05, 2009, 11:55:04 PM »
NO NO!
Lemons in the EYES! :'(
no worries matey!
Haydn
« Reply #7 on: August 10, 2009, 09:44:07 AM »
Howde Folks !
still no luck with this Griffinpowermate!
Could it be it needs some setting up in the ENCODER/MPG,S  in config ports and pins....
Please help....
thanx
Haydn
« Reply #8 on: August 10, 2009, 10:41:10 AM »
Haydn,
I'm also not a user of the Powermate but maybe I can help in some way. Just to be sure you installed the plugin correctly by clicking on it and it will say, plugin installed!
Now Open Mach 3 and with Mach 3 open, in the user menu: go to: Config/config plugins and the config box should come up. Now next to griffin blah blah blah, you should see a red "X" and you should click on that to change it to green check mark. Then click the yellow config box and that will bring up another box.
This is where I will be no help as I do not have one of these but have you at least completed the steps I just mentioned?
« Last Edit: August 10, 2009, 10:42:54 AM by budman68 »
« Reply #9 on: August 11, 2009, 10:11:17 AM »
Howdee Dave
Yea man did excactly as you described before and its intalled ok and switched the axis no problems..just to action on the dial turning..BUMMER!
thanx for your help anyhows..loks like ive wasted valuable money here..for a gloryfied axis changer..the arrow keys are faster!
cheers
Haydn
