Hello Guest it is October 21, 2026, 04:40:34 PM
Author Topic: Pendant Setup  (Read 10118 times)
Pendant Setup
« on: August 01, 2009, 11:23:37 AM »
I am converting my 6' X 10' waterjet to Mach3 & have a pendant already with my present system. It seems like you need to install pendant drivers or software that allows Mach to find the pendant. I don't have any software & my present system is running Dos 6.22. Is there a way to have Mach look for signals from my BOB while pressing buttons on my pendant? My BOB is a custom made 1995 version so I don't know if Mach can see it???? Any tips for me would be appreciated.
Also if that doesn't work has anyone tried Logitech Cordless Rumblepad 2 PC Gamepad?
Re: Pendant Setup
« Reply #1 on: August 01, 2009, 11:39:04 AM »
That depends entirely on how the pendant is interfaced to the system.  If it uses the game (joystick) port, then the standard Mach joystick driver should work.  If it's a keyboard emulator device, or connects to parallel port pins, it should be possible to make it work through keymapping and/or a modified screenset.  If it's serial or USB, then probably not, as that typically requires a custom plug-in.
