Hello Guest it is November 19, 2026, 10:47:57 AM
Author Topic: Importing a part into MasterCam  (Read 17705 times)
« on: July 28, 2009, 02:42:03 PM »
Can anyone assist me with importing a part from Solidworks into Mastercam Lathe. Is it better to use a parasolid or iges file. I cannot obtain a chain to write a toolpath from. I have no problem using either format for Mastercam mill .
Re: Importing a part into MasterCam
« Reply #1 on: July 29, 2009, 05:46:36 PM »
If your a Solidworks user , heres a good forum group.
Hope this works for you.
http://tech.groups.yahoo.com/group/solidworks/
Ed
Ed VanEss
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #2 on: July 30, 2009, 12:23:22 AM »
Hi, Lawley
Use a DXF file Preferably acad12 format.
Edit: I was thinking you were referring to LazyCam ooop's
Chip
« Last Edit: July 30, 2009, 01:01:48 AM by Chip »
« Reply #3 on: July 30, 2009, 12:55:37 AM »
I don't know what version you have but normally, importing files from SolidWorks into MasterCam is quite easy
Select OPEN.
Bottom of window, select the drop down menu and choose :FILE OF TYPE
Select Solidworks files (*.SLDPRT; *.SLDASM)
Also choose OPTION and check  " Import SolidWorks History "
Normally, this will work but sometime, it will not, don't know why
Hope this help,
Jeff
« Reply #4 on: July 30, 2009, 06:16:56 AM »
Hi Guys
Many thanks for the advice, looks like I am coming right with the dxf. This is foreign to me as I am used to doing everything in 3D.
Regards
Brian
