Hello Guest it is September 21, 2026, 11:39:24 PM
Author Topic: Read Jog Key Press or Mouse click  (Read 6485 times)
« on: July 26, 2009, 11:58:02 AM »
Hello,
I'm trying to read a Jog key press from the keyboard (and ideally a mouse click on the jog screen too) from Brains but it doesn't seem to read.  I'm using Jog X- from the input dropdown to start the rung but it doesn't fire in the diags screen or in the watch brain, nor does the output turn on that I'm using to test with.
Another question -though likely in the wrong part of the forum:
I want to create a "move to switch" macro to do homing but I don't want the job to fault when it hits the limit/home switch (actually I want to create an M91/M92).  Can brains be used to override the job cancel that occurs when a limit is tripped?
Scott
