Hello Guest it is November 13, 2026, 01:53:00 PM
Author Topic: V3.042.20 and over "Run reverse" problem.  (Read 10833 times)
« on: July 24, 2009, 06:52:44 AM »
Have you noticed any problem on "run reverse" button (OEM 279) on versions 3.042.20 and over?
Or something is happening to my pc?
Re: V3.042.20 and over "Run reverse" problem.
« Reply #1 on: July 25, 2009, 01:23:30 AM »
Ok, now "run reverse" works.
But only if i do the following.
I installed 042 fully with parallel port drivers.
After that i installed 043 without drivers.
If i install 043 with drivers, still "run reverse" does not run.
Anyway, if the end was good, everything was good.
THANKS
