Hello
Guest
it is
October 21, 2026, 08:53:45 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Does this screenshot mean that pins 12 & 13 are fried on my PC??
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
Go Down
Author
Topic: Does this screenshot mean that pins 12 & 13 are fried on my PC?? (Read 106028 times)
rooney
53
Re: Does this screenshot mean that pins 12 & 13 are fried on my PC??
Reply #10 on:
July 25, 2009, 07:34:33 PM »
result was that whether or not anything is set to active low or active high nothing lights up on the diagnostic tap as far as input signals current state.
I'm starting to scratch my head as my hair is falling out...
Last Edit: July 25, 2009, 07:36:15 PM by rooney
Carnoustie, Scotland
Reply #11 on:
July 25, 2009, 07:36:13 PM »
Can you attach your xml and I will see if I can find a problem.
rooney
53
Reply #12 on:
July 25, 2009, 07:37:06 PM »
Will try.
Thanks Hood.
rooney
53
Reply #13 on:
July 25, 2009, 07:47:36 PM »
Hopefully I did this right....
Reply #14 on:
July 25, 2009, 08:13:14 PM »
Working fine here, set them to Active Hi and perfect. You will need to make sure that 0378 is the correct port address, if it is then I dont understand what can be wrong.
rooney
53
Reply #15 on:
July 25, 2009, 08:28:32 PM »
Thanks Hood,
How do I find the ports if they do not show up on device manager?
Reply #16 on:
July 25, 2009, 08:34:21 PM »
Start, All Programmes, Accessories, System Tools, System Information Then go to Components in that window then Ports then Parallel
rooney
53
Reply #17 on:
July 26, 2009, 09:03:33 PM »
Soooo.......If I get to that point and expand the + symbol and see nothing under either serial or parallel, then I either don't have a driver installed for that port or my computer just is not seeing it?
Update........my attachment doesn't show parallel instead it shows serial.......but under parallel, the same thing is displayed......nothing.
Of course I'm including photographic evidence...
Last Edit: July 26, 2009, 09:05:15 PM by rooney
Reply #18 on:
July 27, 2009, 01:20:26 AM »
Certainly seems like windows is not seeing your port and if windows doesnt see it then unlikely Mach will be able to
rooney
53
Reply #19 on:
July 27, 2009, 06:41:57 PM »
OK....I reinstalled mach3, reinstalled the parallel port and manually configured it to be the 348 number.
Could the problem be that it is a PCI Express card slot? This is my card:
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=3260276
Rooney
Print
Pages:
1
2
3
4
5
6
7
8
Go Up
« previous
next »
