Hello
Guest
it is
August 14, 2026, 09:49:36 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
4 axis
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: 4 axis (Read 12210 times)
marcel beaudry
153
4 axis
on:
July 20, 2009, 02:25:35 PM »
Hello
I understand that when i want to make one rotation of the fourth axis the g code will be g1 A360 f.002 .But what if i want to make more than one rotation of the A axis.
Thank you for your time
Marcel Beaudry
Chip
2,055
Gainesville Florida USA
Re: 4 axis
Reply #1 on:
July 20, 2009, 02:41:08 PM »
Hi, Marcel
Use g1 A720 f.002, There are setting's in Config, General Config page you can change the way it act's.
Chip
marcel beaudry
153
Re: 4 axis
Reply #2 on:
July 20, 2009, 02:47:50 PM »
Hy Chip
So if i want to make 2 turns i just type the total amount of degres needed like 720
Chip
2,055
Re: 4 axis
Reply #3 on:
July 20, 2009, 02:57:45 PM »
Hi, Marcel
Yes, If you set the rol-over to un-checked then you'll see the total amount commanded, You need to play with the setting's to see the different functions.
Chip
marcel beaudry
153
Re: 4 axis
Reply #4 on:
July 20, 2009, 03:04:33 PM »
THANK YOU again Chip
Marcel
Print
Pages:
1
Go Up
« previous
next »
