Mach Discussion => General Mach Discussion => Topic started by: marcel beaudry on July 20, 2009, 03:25:35 PM
Hello
I understand that when i want to make one rotation of the fourth axis the g code will be g1 A360 f.002 .But what if i want to make more than one rotation of the A axis.
Thank you for your time
Marcel Beaudry
Hi, Marcel
Use g1 A720 f.002, There are setting's in Config, General Config page you can change the way it act's.
Chip
Hy Chip
So if i want to make 2 turns i just type the total amount of degres needed like 720
Hi, Marcel
Yes, If you set the rol-over to un-checked then you'll see the total amount commanded, You need to play with the setting's to see the different functions.
Chip
THANK YOU again Chip
Marcel
