Hello Guest it is October 21, 2026, 06:13:38 AM
Author Topic: THread milling  (Read 31520 times)
vmax549
THread milling
« on: July 18, 2009, 10:20:52 AM »
Hiya RON , would you consider adding NPT threads to THe threadmilling wizard (;-) Please
Re: THread milling
« Reply #1 on: July 18, 2009, 08:53:42 PM »
I wrote a simple one a while ago- I had to thread a 3" NPT into a throttle valve for a locomotive boiler I helped build. I actually cut 3 threads, on the throttle, a flange and a ball-socket coupling. They all worked, the boiler passed inspection and got stamped.
I did it as a quick and dirty, it would take some error checking and clean up to make it generally usefull.
Ill see what I can do.
vmax549
Re: THread milling
« Reply #2 on: July 19, 2009, 03:22:00 PM »
I can probably give you and example macro that does it if you need it for a reference
