Hello Guest it is November 13, 2026, 09:41:26 AM
Author Topic: Importing Files From Corel Draw 7  (Read 10580 times)
« on: July 18, 2009, 06:58:38 AM »
Hi
I am new to CNC and looking to purchase a machine from Marchant Dice and run it using Mach 3. I understand that I can produce drawing using Corel Draw and import them into Mach 3.
I already have Corel Draw 7 Select - Is this a suitable version.
Many thanks for your help.
Stez
Re: Importing Files From Corel Draw 7
« Reply #1 on: July 18, 2009, 09:39:44 AM »
Mach accepts a gcode file. Something drawn needs to be converted to gcode.
So you will need a cam progam to do that. Lazycam is provided with Mach and can do the conversion.
It takes more than just hitting a button and it's done.
I don't use / haven't used in a long time Corel ,and frankly, think you would be better off spending $30 and buying a CAD program in my personal opinion.
