Hello Guest it is November 13, 2026, 12:57:05 PM
Author Topic: Probe  (Read 11222 times)
Probe
« on: July 17, 2009, 12:57:41 PM »
I am running a Gecko 540. I ran a wire to Input #4 and another to -V then clicked on Config-Ports and Pins-Input Signals. There I enabled Probe, changed pin# to 13, Changed active low to green check.  At this point I am manually touching the wires together after clicking on the Z button in the Automatic Tool Probing screen.  As Z axis moves downward I touch the wire together and it makes a rapid movement down an additional 1/2" or so before moving up.  What do I need to do to correct the move down after the wires have been touched together?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Probe
« Reply #1 on: July 17, 2009, 02:24:36 PM »
Hi, Tantrim
Look at this Post, It's probably what's going on with your setup.
http://www.machsupport.com/forum/index.php/topic,5673.0.html
Try typing a G49 on the MDI line and Enter key, Then try it again, See if that Helps.
Chip
Re: Probe
« Reply #2 on: July 20, 2009, 09:10:41 PM »
I rebooted the computer and it has corrected it self. It seems to work now. I will look into the site.
